G
		gtrplyrguy
I have a question about the isolation room I am building.  The dimensions will be 7ft by 7 ft and one side of the ceiling is 9ft tall while the other side will be around 4 ft so I have a serious pitch in the ceiling.  I had originally budgeted enough acoustic panels (1 inch or 2 inch pyramid designed specifically for sound rooms) to cover the entire 4 walls as well as the ceiling and also installing bass traps in the corners and where needed.
My thought now is do I want to cover the entire room and have a very "dry" room and add in reverbs after recording? I know that this small of a room will not make very good reverb which is why I planned to cover everything.
Also, I plan on aiming the singer towards the low end (the end with the 4 ft ceiling) to reduce bounceback sound because of the greater than 90 degree corner where the wall meets the ceiling. Would that be best or would aiming them towards the 9 ft wall be better? I liked the 4 ft side specifically because the height of the singers would make most sound hitting the ceiling vs the walls which would deflect the majority to the floor (whatever returned off the acoustic panels).
Lastly, a bit of info to help in the responses. The room will be built as a "room within a room" with the isolation pads under the floor joists, the rest freestanding and nothing touching the existing structure. The insulation will be 4 inch batt on existing structure, 3 inch air gap, 4 inch batt on isolation room, layer of mass vinyl, 2 layers of sheetrock hung on iso channels and clips. And lastly, the room will be carpeted with a thick pad underneath and floor will have mass vinyl and 8 inch batt.
Im going to this expense because my neighbors are close, our living area is on the floor below, and their is traffic and dogs close by so I needed to build fairly soundproof.
Any ideas or recomendations are, as always, very welcome.
Edit to add: This room will be for vocals and acoustic guitar as well as occasional saxophone or cabinet micing only.
