mshilarious
Banned
So I just finished an A/B test of these two mics on toms (shallow; 10, 12, 13, 14 with Fiberskyn heads). I tried 1" above head, and 3" above & between two toms. I wasn't surprised when I preferred the MD421; it's a lot more expensive after all.
The MD421 had a great controlled sound, nice tight bass response (no bass rolloff engaged) with the perfect treble boost to define the stickwork. The SM57 was boomy and uncontrolled, and a little noisier (not self-noise, but useless high-end clicks, vibrations, cymbal bleed, etc).
But looking at the frequency response charts, I have trouble understanding why. The MD421 is dead flat from 1kHz down to 100 Hz; whereas the 57 drops off at 200 Hz with a little dip at 400 Hz. So I don't get that the 57 should be bassy. The treble peaks make sense; the MD421 peaks at 4-5k but the 57 at 6k.
I'm wondering why I have so many 57s. I used to have 5, I sold 2 & now I'm down to 3, plus I have a 58. But I also have an SM7, and a Beyer M88, both of which are much nicer than the 57 or 58 for vocals. Now I don't like the 57 on toms, and I don't record guitar amps.
Have I reached the post-57/58 plateau? Should I sell 'em & buy another MD421 and an M201?
. Sounds like you have reached a plateau. I didn't start upgrading gear until I could hear the limitations of what I already had. When I wanted to upgrade from my first set-up cause it sounded bad an engineer friend of mine laughed and told me the better my ears were the more money I was gonna spend.
). I read your posts, and you know what you are doing (I've learned a thing or two). Sell the shures, get what you like. The 421 sounds great on just about anything. Don't know the 201........
I'm gonna miss it.
