Tie line wall plates
jamesmlaw
jamesmlaw
I'm trying to build tie lines between my isolation booths. I can find 12 ch snake cable. But I am unable to find 12 channel XLR wall plates. Does anyone know where to buy these. I can find 6 channel ones but nothing larger. Ideally I'd like to have 10xlr and 2 TRS returns for headphones. Thanks for the help!
Where in the world are you James? I can have a look at people in EU. If a "10+2" really cannot be found you might approach a small local metalworker? I know a couple of shops in my town who could whip one up in no time with a CNC miller!
I'm in BC Canada. Can't seem to find anything big enough online
Neither can I. I have found this, https://www.gear4music.com/G4M/Studiospares-12-XLR-4-Jack-Stage-Box-and-Snake-8m/7138
Which you might be able to modify? A thought occurs though? Wall plates need to screw to a standard back box. Maybe find a box for a "switch grid" then get a friendly engineer to mill you up a plate to fit? You could save a few $CA by just having him make the big holes for the XLRs and jacks. The multiple 3mm jobs you can do yourself. Investigate "Taptite" screws.
From Studiospares at Gear4music.
Other sizes available.
I have one, and will get another. Just stick the box inside your acoustic booth.
Yeah I would go with something like that the only issue is feeding the tail through the walls might be difficult. That's why I thought just buying the cable and building my own terminations. Maybe we need to start a wall panel business online 😂
I'm set up to solder just looking for the plates
  • international@canford.co.uk Give them an Ee! Soldering? You are probably going to have to use lead free solder so get some good, i.e. expensive stuff. If you don't already have one, invest in a cable tester which will test 3 wires for continuity and 'polarity'. LAST thing you want is an XLR or two out of "phase" buried in the wall!
  • Also, I don't know what cable you have, have planned but I suggest looking for some foil screened 2 core of about 3mm OD. This has a drain wire earth and is a dream to strip and solder. No braid to pick apart. Maybe get some automatic cable strippers?
  • Another very cost effective cable is shielded CAT 5e. Four balanced pairs per ~6mm sheath. In any case I hope you are installing a few CAT 6 outlets?
Don't know where the blobs came from!
