Tie line wall plates
jamesmlaw
jamesmlaw
I'm trying to build tie lines between my isolation booths. I can find 12 ch snake cable. But I am unable to find 12 channel XLR wall plates. Does anyone know where to buy these. I can find 6 channel ones but nothing larger. Ideally I'd like to have 10xlr and 2 TRS returns for headphones. Thanks for the help!
Where in the world are you James? I can have a look at people in EU. If a "10+2" really cannot be found you might approach a small local metalworker? I know a couple of shops in my town who could whip one up in no time with a CNC miller!
I'm in BC Canada. Can't seem to find anything big enough online
Neither can I. I have found this, https://www.gear4music.com/G4M/Studiospares-12-XLR-4-Jack-Stage-Box-and-Snake-8m/7138
Which you might be able to modify? A thought occurs though? Wall plates need to screw to a standard back box. Maybe find a box for a "switch grid" then get a friendly engineer to mill you up a plate to fit? You could save a few $CA by just having him make the big holes for the XLRs and jacks. The multiple 3mm jobs you can do yourself. Investigate "Taptite" screws.
From Studiospares at Gear4music.
Other sizes available.
I have one, and will get another. Just stick the box inside your acoustic booth.
Yeah I would go with something like that the only issue is feeding the tail through the walls might be difficult. That's why I thought just buying the cable and building my own terminations. Maybe we need to start a wall panel business online 😂
