D
DevD
1) MUDDY SOUND - I do everything that can be done to broaden the sound , compress, eq , cut lows, dip muddy freq , choose best of sounds while programming , use very little but best plugins , YET when I compare my sound with others, neither it sounds as powerful nor as sharp at mixing stage ..... this power all I can think of achieving might be by increasing loudness... and sharpness by increasing the high frequencies in mastering .....what do you all think how can it be achieved .....?
2) NOT SO MUCH DIFFERENCE BETWEEN MIXING AND MASTERING :Teachers say you should be quite close to the final mastered sound at the final mix stage , and not wait for mastering to make it sound good .....as far as I am concerned , my final mixes are nowhere close to those professional mastered reference tracks..... mine seem far unclear and muddy in the final bounced mix....is this the difference of hardwares in professional studios and limited softwares in home studios..?....or truly all magic happens in mastering and I am bad at it may be ? your views plz
3)ALL VSTS HAVE PROCESSED SAMPLES NOW A DAYS ..... and sometimes mixing engineers expect you to get untreated uncompressed dry sound ....does that mean you all programmers remove all effects (compression , reverb, delay etc)of the plugin and then record the sound ?, but you would not have chosen that sound had it been so dry .....so do you all remove all effects before giving for mixing ? is it unprofessional to give sounds with effects to the mixing engineer...?...but sometimes there are no options to remove certain effects that you can hear in the vst.... What do you do ?
Plz help ,thanks.
Plz help ,thanks.
