A
assmaster
this is two different thing or its the same thing?
thanks
thanks
assmaster said:this is two different thing or its the same thing?
thanks
apl said:Read this. I wouldn't put that stuff on my walls. Ever.
assmaster said:what i will need to buy to make a room that is 152 inch on 104 inch
acoustic for recording a vocal or instrumental
i see this on ebay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=7322735084&rd=1&sspagename=STRK:MEWA:IT&rd=1
it will good for me?
thanks
Mach311 said:Rod, how do you know the product has never been tested and the numbers aren't real? Do you know the sellers or what? Just wondering.
Rod Gervais said:Their products were purchased (recently) by another company (not Auralex) and submitted to IBM for testing - and the test results were nowhere NEAR their published numbers,
Rod
Mach311 said:Do you have access to these numbers? It would be pretty beneficial for all of us users here to have those real numbers so we could do our own comparisons and weigh the cost vs. performance for ourselves. I have seen other posts on this message board from people who have bought from foambymail who were pleased with the product. I'm just trying to get the best value for my extremely modest home studio.
Mach311 said:Unless I'm misinterpreting the test results, which is very possible, it looks like they are honest about the 3" foam anyway.
Maybe you are missing something. You don't know for a fact that they didn't test it, you are just assuming they didn't because you can't trace it to a lab. It appears the results for the bass absorbers is way off, but I'm only trying to figure out if their 3" foam is comparable to Auralex. And it appears it is, according to the test that RealTraps did. So I don't really care if they did test it or didn't test, as long as somebody tested it. Apparently it does the job for a lot less than the Auralex.Rod Gervais said:Am I missing something here?
Mach311 said:Maybe you are missing something. You don't know for a fact that they didn't test it, you are just assuming they didn't because you can't trace it to a lab.
You said "Their product and the Auralex product are 2 very different foams with completely different properties". If that's so, then why does 3" of the Auralex and 3" of the FBM yeild practically the same test results?
there IS a foam with a layer of lead in it that I use a fair amount to shield engine noises and stuff like that on boats. Quite a common product, actually. I will knock 20 dB off or so...but still lets the "rumble" through! When soundproofing generators in smaller sailboats, it is well worth its use, especially if you can bring the overall noise level down to "tolerable"!!Rod Gervais said:There is no such thing as "soundproofing foam". It doesn't exist - never did.
Soundproofing requires mass - which foam doesn't have.
Foam is manufactured for a lot of things - but in the case of sound - it's an acoustic treatment.
I hope that helps,
Rod
mixmkr said:there IS a foam with a layer of lead in it that I use a fair amount to shield engine noises and stuff like that on boats. Quite a common product, actually. I will knock 20 dB off or so...but still lets the "rumble" through! When soundproofing generators in smaller sailboats, it is well worth its use, especially if you can bring the overall noise level down to "tolerable"!!![]()
