minofifa said:
i am thinking along the same line as newbmediaguy. I just ordered the keyboard MIDI controller he mentioned (coincidence) and it is connected to the computer VIA usb. So Brazillian if i run several soft synths this controller will have high latency because it is USB? hmmm that will suck... i wonder what the point of having USB midi controllers is.
You are confusing a lot of terms here and I don't have the time right now to explain it all.
When you're talking about latency with your soft-synths you are dealing with audio, not MIDI. All hardware will introduce a certain amount of latency because it takes time for a computer to process any information. How bad it is depends on a lot of factors; drivers, interface, hardware (soundcard), processor speed, memory, etc.
While USB is not ideal for MIDI, there is no question that it can handle what you are talking about. There will be a small amount of latency (7-8ms) but that is lower than you are going to be able to perceive.
NewbMediaGuy- you were concerned about problems with USB MIDI interfaces. The technology has matured to the point where the problems that people had originally with incompatibility between mobos and drivers have been eliminated.
The kind of latency you are worried about is most often related to the soundcard and, in particular, the drivers for the soundcard. This is why everyone tells you not to use a SB card. It has MME drivers and they will make it impossible to monitor and record (overdub). Better are ASIO and WDM drivers.
If you can afford it, you will get excellent performance from dedicated MIDI interfaces, using USB, from Edirol and Midiman and MOTU as they use technologies to improve the performance of MIDI over USB.
I'll try to find some information and post it here later (tomorrow).
Ted
