storoi90
Hi!
So i just got the K-meter demo from Audio Pluggers, and i need some help confirming or dismissing my understanding of how the correct levels work when recording and monitoring.
The plugin comes with a K-12, K-14 and a K-20 setting, which i assume is the equivalent to -12 Dbfs, -14 Dbfs and -20 Dbfs. And the way you check your correct levels is if your hitting around 0 RMS (the average).
Now in one of my sessions, i put the plugin on the master bus and on my individual tracks to check my levels.. and they were HOT.
The master had around +6 RMS, and was peaking at +18 RMS.. which i assume is to much.. at least if you´re going for the standard clean music, with headroom for the master engineer (which i would like to try for a change
). The individual tracks i looked at were all a couple of RMS over at K-14 setting.
Now, i just started getting in to the importance of gain staging within a mix, and i wanna get this RMS-input thing right when i am recording.
The guys at Audio Pluggers talked about compressors and EQ´s wanting to have an input level of around -18 to -20 Dbfs (and that also goes for plugin-versions) in order for them to function properly, and not distort or emulate distortion. This is where i need conformation on my understanding on this. Here is my thought process on this:
If i have an instance of Battery 4, and i record a MIDI kick. Then i bounce this MIDI to Mono Audio, and i check with the K-meter at K-14 setting, and i see an RMS level of +6, and the peaking is even higher.. that´s to much right? That would indicate that the signal was recorded at -8 Dbfs - right or no? (-14 Dbfs +6). if that´s the case, then the reinessance compressor i use for the Kick-audio, is receiving to much input according to what it want´s, and it´s distorting. It´s actually receiving 12 Dbfs more then what it´s designed to work with.
So what i am thinking of doing, is before i bounce my MIDI kick (and my other MIDI sources) to Audio, i check that it´s average RMS level is around 0 on the K-20 setting.
This would indicate that the audio was recorded at around -18 to -20 Dbfs.
This would in general mean i would have to lower the output volume of most of my VI´s. Taking Ultrabeat for instance. To get the right RMS level, i would have to turn the master output down to around -10 (default is at 0), in order to record at around -18 Dbfs.
Now i know i have a "healthy" audio file, that the compressors/EQ plugins want to process without distorting it.
Am i on the right track or no?
