D
Danglez
It's the boot.ini file. Should be able to find it at the root of your c drive although it will prollally be hidden. Just excersise the normal amount of caution when modifying it.....I'd just rem out the offending lines..Prollaly best to make a copy of it b4hand in case you totally screw it up ( you won't be able to boot if you stuff it ).
Cheers
Danglez
Cheers
Danglez
