The Best XLR Cords
  • Thread starter Thread starter T.O.I.Y.Z.
T
T.O.I.Y.Z.
What is the best brand and type (model if one) of XLR cords?....I have a Sterling ST51 and a MXL 2006 and both had standard XLR cords running from them.....I wanted to know if there was a better type, that might affect the audio signal transmission in a good or better way
Does it have a shield? Does it have two wires in it? Then it's a good enough cable for 99.99999% of home studios. Seriously, I've heard no audible difference in normal use between the light-duty installation cable I use for my drum kit mics and the heaviest, most well-shielded cables I've used. Maybe if you're running at an exceptionally high gain for a low-output ribbon mic, it might matter... maybe... but probably not even then, realistically speaking. In a home studio, the rustling of your hair in the slight breeze from convection currents rising off your torso is likely to make a more audible difference....
Where the difference between cables can be important is if you are in an electrically noisy environment. If you're going to be in a theater around lighting dimmers, you'd better have good shields, and perhaps more importantly, the outer metal sleeves on the XLR connectors MUST be grounded if you ever plug one cable into another. If you don't do this, you WILL get hum, and it will be massive. :D
I guess what I'm trying to say is that in terms of sound quality, I wouldn't worry about it unless you are experiencing problems.
Now if you want to throw build quality into the mix, my advice would be to get the heaviest gauge cable you can find, and only use cables with a braided shield. Thinner wires and wires with foil-and-wire shields are fine for permanent/semi-permanent installations or for occasional use, but they really don't hold up well. Fortunately, you're unlikely to encounter either unless you make them yourself....
Put another way, with the exception of actual miswiring of the cables (failing to hook up the ground pin, failing to hook up a signal pin, or hooking two cables with ungrounded shields together), the components of a good recording in order from most important to least important:
  • performance (voice quality, musicality)
  • room/location (environmental noise, reflections, etc.)
  • song (does it suck?)
  • competence of the engineer (including microphone placement, mixing ability, etc.)
  • microphone
  • preamp
  • converters
  • dithering vs. truncation vs. rounding
  • dithering algorithm
  • clock jitter
  • use of balanced vs. unbalanced line-level interconnects
  • color of the performer's jacket
  • phase of the moon
  • barometric pressure
  • mic cable quality
Any questions? :D
I am asking because I am having problems with this Sterling ST51 mic.....it only happened in the last few days......Seems like when I switch cables, the mic will work again and then go back to acting up....When i say acting up, I mean the sound will go in and out with an electronic short in the vocals/audio.....So it seems to be cord related.....Then when I looked up cords on the web, I noticed there are all diff types of prices for them....From what I am seeing, these Mogami and Planet Wave mic cords are supposed to be the best, but I wanted to see if anyone on this forum could confirm they switched cables and noticed a difference!!
Are you saying that you switch cords and it still happens? If so..It sounds more like your mic. Are you using a Pop filter?
Agreed. If you've experienced it with more than one cable, that sounds like dirty switch contacts or a loose wire on the connector inside the mic.
The most frequent problem I've had with XLR cables is bad connectors, specifically the female end. The cheaper ones spread out or get deformed and start having problems. I like Switchcraft jacks, though Neutrik are probably good enough too. The problems ones I've had are mostly no-name connectors on cheap cables.
maaaaan......I had 2 artists over last night, and after I had just purchased all new cords from Sam Ash, the daggone thing started doing it again....So this time I did more testing, all that while beyond pissed off......Got it narrowed down to the Behringer MIC 2220
Try EWI cables at Audiopile.net.
They have standard and now have Neutrix ends at a reasonable price.
T
Try mogami cables there cheap.....I can tell the difference from a cheap cable to a high end cable.I have a brick floor in one of my tracking rooms and when a cheap cable is lying on the brick floor there is noise.My mogami cables , no noise.Everthing is more clear and noise free.
Ah. That would be the Behringer Ultragain Pro MIC2220.... So you tried a different preamp and the problem went away?
[*]color of the performer's jacket
[*]phase of the moon
[*]barometric pressure
[*]mic cable quality
[/list]
Any questions? :D
Just thought I'd say that that made me laugh pretty damn hard.
Color of the insulating jacket doesn't mean much to me, but if it makes you feel better, then by all means...
Mogami isn't bad for the price, but what I've been getting a kick out of in my own place right now are the Redco cables. Custom stuff, great quality, and the cost is very reasonable.
Just my $0.02 worth.
What a surprise.
Cheap cable will wear out faster and will come with cheap, fragile connectors much of the time. By "cheap" though, I mean really, really cheap. The average Horizon/ProCo/Comprehensive stuff is fine. Like dgatwood said, I'd put expensive mic cable down at the very bottom of the "must aquire" list.
Frank
Start with Behringer, everytime, and work backwards....
