MISTERQCUE
Not Just Anutha Brutha
I found a few uses for the 3630 other than doorstop,coffeetable,step-ladder etc. Forget about it in the area of compression,but it does produce some strange
and crazy bass effects.If you hook up the 3630 into a channel insert plug in your bass,set the thresh and ratio
@ .20 and 1.1 respectively, use a .1ms attack with 50ms release,disengage the gate and roll-off freq at 75hz you get a airy "Cello-like" harmonics tone similar to cathedral like chamber music. OR, if you set gate at 1.5ms and thresh/ratio at infin-.1;attack/release@1.5 and 1.1ms respectively,increase EQ freq-gain at approx 60hz with a little 'verb,it produces a deep,harmonic "FOOOSH" sound like a deep jet flange but less "WOOOOSHIER"!.
Now that you all have finished laffin' and with thought's of
"Dude,you gotta get a life!",I just felt that with enuff patience,1 can find a viable use for the 3630 other than what the product is intended for. 'Cause the 3630,sure doesn't work in the field of compression,but with experimentation,it does produce some cool bass effects.
Try it if you own 1,and if not, you wanna buy mine?? Dirt Cheap!!!!
