Slack,
> Let's say that your realistic noise floor is at -70db. That means you can damn near toss off 4 of your least significant bits unless the noise you're recording is desirable. <
Yes, though when there are fewer bits the distortion rises too. An 8-bit Wave file is not only noisier than a 16-bit equivalent, it's also grittier sounding.
> You know what I thought the big clincher would be? The fact that you've got 8 MILLION voltage levels to choose from between 0 and -6db in a 24 bit system. <
But that doesn't really matter because even with 16 bits the distortion is negligible. Further, consider that those tiny steps in voltage are sent to a loudspeaker, where they are translated to tiny steps in the speaker cone's position. If a tweeter has a maximum throw of 1/4 inch (and most are probably much less than that), you're talking about micron sized displacements! I don't know how many loudspeakers can be positioned that accurately.
> After a certain amount of resolution, it's probably the clock and the accuracy of the sampler that has the biggest impact on sound quality. <
That too is not the problem so many people seem to think it is. If a clock source has discrepancies that occur in the MHz. range, then the only affect is MHz. components. Which are filtered out in the D/A conversion but would be inaudible even if they weren't.
> The difference between the two mixdowns was extremely minimal. In fact I used wavelab to create a "difference" file, and the only differences were WAY down like -80db. <
My main point exactly.
--Ethan
