Shailat
Another thing to think about........
On what kind of system are the judgers listening to.
Is it on computer speakers?.
Yes, but there's no consumer standard for distributing 24-bit files. So any advantage 24-bit could offer is realized only after dithering down to 16 bits! And if you can't tell the difference after dithering, then why bother in the first place?
I already acknowledged that! If you'd like, I'll withdraw the test, erase all of the threads that discuss it, and never bring it up again.
Originally posted by ff123
One more point, If File4 and File5 were compared directly against each other, with no other files in the test, then only 6 people in agreement would be required (using the LSD formula) to say the two files are significantly different. The moral? Fewer files to compare at the same time means more powerful results.
ff123
Edit: before somebody asks, I already tried eliminating File4 and File5 from the analysis of the 10 sensitive listeners. It does show then that File2 is preferred over File1 with a confidence > 95%. Problem is, I'm not real comfortable with doing this. The proper method in statistics is to conduct another experiment to confirm results like this.
) and 4 and 5 as "like an old radio" but didn't care to rank further than that, knowing even less about dither etc. than I do.ff123 said:The proper way to interpret the group statistical results is to say only that files 4 and 5 were distinguishable.
There is the suggestion in this data that file 2 was rated better than file 1; however, that was not proven by this experiment -- a confirmatory experiment must be run to test this question separately.
An individual listener can "prove" with high confidence that he actually can hear a difference (as opposed to just thinking that he can hear a difference) by performing an ABX test.
See: http://www.pcabx.com/
If an individual listener can demonstrate that he can achieve significant ABX results for file 1 vs. file 2, I would like to know about it.
If someone decides to perform an ABX test (it won't be me, because I didn't hear a difference beyond the 11th bit), I would recommend using my ABX probability calculator (http://ff123.net/abx/abx.html) to figure the probability that you arrived at your results by chance. Once you perform enough correct trials to get to a p-value of 0.01 or lower, you should immediately stop (you might mess up your results by continuing!) and crow about your highly sensitive ears.
It is possible to achieve p=0.01 or lower with as few as 7 trials (as long as you get them all correct).
And no fair performing multiple ABX sessions to "cherry-pick" the best one. You must count all trials in every session in figuring out your overall p-value. Of course, this doesn't preclude you from breaking up ABX sessions over time to prevent listener burnout. In fact, short listening sessions are recommended.
ff123
ff123 said:I'm convinced you are actually hearing a difference between files 1 and 2!
But can you explain the number of trials again?
13 masochistic runs of which you got 8 correct, plus some more sessions spread out over time which added another 11 total trials (which you got all correct)? This would add up to 19 of 24.
This is the first such demonstration I have seen of someone "proving" with high confidence that he can hear the difference between truncation and dithering at 16 bits.
ff123
Doesn't do any good at all to hear high frequencies if you don't know that you have to mix in mono to get translatable mixes and no phasing problems, LOL. Thanks again, ff123, for the ABX program. The playback isn't as detailed as Samplitude's (in the ABX the telltale "waffle" 3/4's of the way through File 1 is not audible) but it's not a mastering program and doesn't need to be. In another test with my own stuff, the ABX debunked an illusion I had about two other files- those particular files are really either the same or "might as well be", which is good to know.
ff123 said:
Arny Krueger, the PCABX author, says this about his program (in rec.audio.pro):
"I don't know what Samplitude does to .wav files, but I know for sure that PCABX is absolutely bit-perfect. I tested this by playing 16 and 24 bit files with PCABX.EXE through the digital output of one sound card and into the digital input of another. BTW, I repeated this test in the analog domain to get an idea of how long it takes to switch files with the switching delay set to zero.
PCABX.EXE is a Visual Basic program that never gets any closer to the files than their names. It starts and stops the Windows multimedia .wav file player on cue, running in millisecond increments.
Samplitude may do some resampling of .wav files when it plays them, as I know for sure there are situations where CoolEdit Pro resamples to play 24 bit files on computers with 16 bit sound cards. It doesn't change the files unless you formally ask it to, but it does do some processing that might be hidden to some when it plays files. AFAIK it won't change sample rates except when formally asked to."
ff123
