B
boxbat
I bought a Tascam US-1641 interface about a year ago and used it with the CD it came with, Cubase LE4. I got a couple of decent recordings out of it on my laptop (a Dell inspiron 1525, in case that's important) but only had time to use it sparingly.
Now that I have the time and inclination to use it again there's a problem - effectively Cubase doesn't seem to pick up the signal from the microphone. I change the Device Setup and VST settings accordingly, and 'US-1641' comes up next to the input and output channels. The lights on the interface flash when I speak into the microphone attached to it, yet nothing records. Instead, when I click record, I get just a thin blank line where the waves should appear and, furthermore, when I click to stop recording that part of the track disappears completely (I'm not left with just a silent or blank track - it looks as if I never tried to record anything).
It seems that Cubase doesn't pick up any signal from the mic, whether I'm trying to record or not.
HOWEVER... On rare occasions, normally when I first enter Cubase, it does recognise the mic, and I'm able to make a recording, complete with wave lines, and, for a short while, can listen to it back. The next time I try to record any sound, though, it reverts to the disappearing blank line mentioned above. It's as if the connection cuts off half way through (but not because the USB comes loose - I've checked!).
Clearly the potential is there, but there's a fault somewhere. Anyone come across this before? Help would be much appreciated, I don't know what to try. Thanks.
P.S My laptop crashed a few months ago and I had to reinstall Windows, Cubase et al. Something must be different now from the pre-crash days, but the laptop works fine otherwise, so I don't know what it could be.
