The other ideas summarized:...
EQ: I think the 244/246 has the better 2-band sweepable EQ vs. the 424mk's 3-band/2-fixed/mid-sweepable EQ. A 2-band sweepable EQ enables you to dial in on the sweet spot(s) of different instruments better, vs. the tendency of 2 fixed bands beyond a certain point to possibly be adding mud to the mix rather than clarity.
Mixer: I think the 244/246 mixer has less hiss and less crosstalk, incl. more isolation between the buss section and the cue section in the headphones. The patch points are by far superior on the 244/246 mixers.
Transport: Either is good. I'd not sweat this feature. Both are belt driven and fairly stable, but the 244/246 has a slightly larger flywheel. Larger would be more momentum and stability.
Heads: I believe the 244/246 vintage recording head would likely have a better build quality, as well I believe (at least the 244) had a reverse phase relationship between the track elements in the head to minimize crosstalk. I've also verified this by swapping recorded test tones between families of machines. I believe
Tascam abandoned that reverse track phase head arrangement when they woke up one day & moved into a "let's be compatible" mentality. So, the 244 (& family) head/amp section has less crosstalk in theory & I believe also in reality (listening tests). However, in turn I think the 424mk's head might have more overall sensitivity, being a more matured design of the coils, which might exacerbate the crosstalk. Keep in mind we're talking about miniscule amounts of crosstalk. I don't have the spec sheets in front of me.
I don't want to portray either unit as "bad" comparing to the other sounding "good". They both sound good.
Features: I think the 246 being 4-buss (mixer section) trumps the field under discussion, pretty much for that reason alone. If you don't understand that now, in a fairly short time you will.
Other Features: The 424mk series has some very sophisticated transport functions that the 244/246 can't answer for.
Other: The 244/246 are fully self-contained, as well as the 424mk2, but the 424mk3 has the inline power module that often gets separated from the mixer unit, which is undesirable. I also think that a Portastudio should be a one piece solution by definition, and a separate power module spoils the pristine nature of that idea, but maybe I'm nit picking there. Alternately, the inline power module design isolates the noise generating elements of the power supply from the R/P & mixer sections better, and also requires less shielding in the design of the audio electronics. However, the 424mk3 without it's power module is useless.
The 246 only lacks XLR inputs, but in many respects might be considered "best" Portastudio that can make the "best" recordings, however any sonic anomalies the others might have in comparison, or might not measure up (I think) should be regarded as very minor and subtle differences. It's not like night & day.
As with any feature that can help make sound recordings better, maladjustment can also make the sound worse, so there's a whole other post about how the features are applied and brought to bear on the source. That speaks to the techniques & skills of the user. A post maybe for someone else or another day.
Just because I might say atm the 246 is the best one, it's just an overall opinion & doesn't imply the other ones aren't good choices, but they are each a different flavor of hardware with slightly different featues. They are all good machines that can make high quality recordings. Any sound quality differences would be very subtle.
