sweetbeats
Reel deep thoughts...
Hey, Christian,
Thanks for joining and posting. Welcome!
The disadvantage to using the direct outs is patching and submixing. This doesn't matter to you if you always run one source to each track and you don't change your setup (i.e. so you don't have to repatch sources to different channels to get them on different tracks), or if you don't mind repatching. Like if I had drums mic'ed with three mics, bass in another channel, guitar in another, keys in another and two mics for vocals, that would use up 8 mixer channels and 8 tracks. If that is the way I run recordings all the time, like in a rehearsal space or tracking that lineup live consistently, then using the direct outs is the way to go.
Now, what if the setup/lineup changed all the time, like if you were running an 8-track project studio with that M-308B and had different instrumentation day in and day out? What would you do if you had 5 mics on a drumkit and only wanted to use 3 tracks on a multitrack recorder? You'd submix them right? And the submixer would let that happen and better yet you'd be able to put those 5 mics into any three tracks you want thanks to the fact that the M-300 mixers have two outputs for each PGM group...and you'd be able to do it with the press of a few switches and the twist of a few knobs on the control surface. Fast, convenient...I come to think of the submixer (the PGM groups) as a infinitely variable summing patchbay (that is 8 in and 4 out on the M-308).
The other thing to think about is this: in an age when so many are trying so hard to get the cleanest signal to the recorder possible, it is totaly possible to bypass something in the signal chain that might add something nice. I've spent a lot of time avoiding the submixer to stay away from added noise and distortion...nothing wrong with that but you might be surprised at how things sound when they go through that "unnecessary extra" circuitry, and the added headroom might be just the ticket. Something to think about. If you typically track no more than 4 tracks at a time, you've got options. Try them out and see what sounds more appealing to your ears...plus you might like punching more buttons and twisting more knobs to get your routing setup instead of repatching.
Hope that helps...at least you've got one opinion.
What do you track with?
