F
freightliner009
Hi all,
A newbie to the forum and have a bit of a dilemma that I'm sure someone can put me right on
I have a Tascam DR05 but want to try and use a SoundTronics ST2 condenser mic for acoustic guitar recording. Now all gear is relatively new and all working, until I bought a female XLR to stereo mini jack and a phantom power supply for the mic. Set it all up and it doesn't work. I can use a normal mic with the DR05 and it's ok, so the Tascam input is ok. I have tried the mic in a Tascam 8 track using the built in phantom power and that works fine too. It's just using the condenser/phantom power box/female XLR to mini jack doesn't want to work on the DR05, any thoughts anyone?
Although a mono mic, I would expect the stereo mini jack to split the signal to left and right channels albeit not a 'true stereo' signal, right? If I pull the mini jack out of the input by about 5mm it will work but obviously unusable like that, but I know the input is ok as a standard Sure mic works ok like this, I'm confused, please help?
Many thanks,
Andy.
Many thanks,
Andy.
