tascam dm 24 to cubase transfer data.. help!
  • Thread starter Thread starter reverendo
R
reverendo
does anyone know the correct procedure for transfer automation data from dm 24 to cubase sx via midi???
thanx. :)
Automation transfer(?) to Cubase
You can back up your Automation info from the DM-24 as a MIDI file. I don't believe you can transfer mix information from the DM-24 to Cubase so that the same automation can run in Cubase. You may want to check with tech support but I believe the MIDI file created when backing up theautomation creates a file that can only be used by a DM-24.
