D
Doug_3
Recently while using my 688 I've had an annoying problem persist and it has started to get worse. While either in record or playback the tape will stop (just as if you had pressed the stop button) and immediately on stopping the counter/clock resets to zero... At first i thought maybe the tape was not in correctly and was causing it to do this but that does not seem to be the issue, and I have no idea why the counter would reset on its own.
Anyone know what the problem could be? I'm hoping this is somewhat common and there is an easy answer or solution.
Thanks!
Thanks!
