Z
zmb
I'm having a problem recording stereo signals into my Portastudio 414mkII. I want to use the stereo inputs 5-6 in combination with the normal tracks 1-4 because I have a drum machine that outputs in stereo and I can do all the mixing I want in the drum machine itself, no need to use up two full-featured tracks..
My recordings are coming out seemingly in Mono, or as if only the left or right signal is being recorded to both buses on the tape. I made a recording to demonstrate. I'm playing a wide-panned stereo sound into the stereo input 5-6, no inputs on tracks 1-4. Just FYI, tracks 1-4 are all set to L or R bus on record function and are panned directly in the center.
For playback, I turned the tape cue knobs on tracks 3 and 4 to maximum (i.e. to listen to what's been recorded onto the left and right buses) and the monitor switch to tape cue.
The first portion is just monitoring my instrument before any recording, you can hear the high hats panning back and forth. The second portion is what I recorded to tape, playing back via tape cue as described above. It sounds like a mono signal getting louder and quieter. Indeed it is that, if you want to download and look at the waveforms.
View attachment Untitled.mp3
I'm using Maxell XL II high bias tapes and I cleaned the tape heads with some radioshack head cleaner last night. Thanks for any help.
