2488neo multi-task buttons
  • Thread starter Thread starter Tru
T
Tru
Member
Hello. I am aking progress with the Neo, or so I thought. On the Neo I have track 1&2 stereo drums. Tracks 5&6 stereo bass. Tracks 9&10 guitar. I was working with the pan and eq on 9@10 something strange happened. I need to mention that input H was routed to 9&10 and that was all. I started messing with multi-effect and suddenly the mix sounded different. Quieter. I was looking for what happened and when I checked the input routing the sceen showed every input had been assigned to an output. At that point, it was late so reset the inputs but it didn't help the sound. I shut it down . I wonder if I inadvertently hit a button and didn't catch it or something. Has anyone experienced something like this? It is disheartening to work with this machine. It just kills creativity. Thank you
I'm not sure you'll find a lot of support here as there are not many 2488 owners hanging out here. I own a similar machine - but not that one - so I have no idea. Assuming you're Neo is fully functional - the "disheartening" part should fade as you learn and get used to it. I've heard many other folks exclaim how much they love the Neo. Best of luck. You may also possibly find support and other users here:
I feel you. I am working with my neo and I like what it does but then it does something like you are describing. I have no answer except with the multifunction buttons make me feel like I am guessing all the time. I have .ost a lot of songs. Good luck
Are you answering yourself 3 years Later?
Tru, two checks on the 2488neo might make this easier to pin down. Press SHIFT, then MAP to inspect the current routing. The screen lists A–H as horizontal lines. An input is assigned only where a vertical line joins it to a track number. For a quick check of your guitar input, hold H by itself and see which track SELECT keys flash. Release H before touching another key so you can check it without toggling a route.
Then hold MULTI by itself to see which input or track has that insert effect. That tells you whether you were editing the guitar input or the recorded track. If the map still shows H going to the intended pair, focus on the effect assignment and level before changing the routing again. Given the lost songs, try this on a copy made with MENU → SONG → COPY. The Tascam manual covers MAP on p. 30, the multi-effect on p. 41 and song copies on p. 46: https://www.tascam.eu/en/docs/2488neo_Manual.pdf
