J
Julien D
Hi
I just bought a TASCAM 388 in good condition but full of dusts on the outside and inside. I cleaned everything and it is now perfectly clean. Heads are currently in good condition. I cleaned them with isopropyl alcohol 99.9% and I can record all tracks easily. I bought a new tape (RMG LPR 35 1/4) and the mixing part works well. The capstan belt is good.
When I tested it the first time, I could not use the functions play, rewind and fast forward so I checked the fuses and one was burnt. I changed all the fuses. It worked better but I still had transportation problems. I then adjusted the tension of rollers on the reel servo pcb (R112, R212, etc ..) and it finally works !!! I then tested the recording of all tracks. Everything worked.
But then I noticed that the tape counter remained at zero when the tape was running. So I verified the tach (counter) roller and the sensors and everything was ok ...
So I decided to unplug the connectors on PCB boards (capstan servo pcb) in case. When I turned on the machine after that, I saw smoke coming out (between pcb power supply and reel servo pcb I think) and I immediately switch off.
A fuse has burned out ... I changed and I reconnected the connectors on the PCB board. I switched the machine and the same fuse burnt again if I remember correctly.
I changed again and I tested the play functions, rewind and fast forward. Nothing worked properly. I still set the tension of rollers (R112 and R212) and I can now use again play function but I can not rewind and fast forward ...
I made a video to show you my problem:
https://www.youtube.com/watch?v=EC5mqNMwYKQ&feature=youtu.be
I feel that the roller pitch engages in all cases when it should be engage just when I push the play button, right?
Thank you for your help!
Julien
PS: the tape counter is working now ... I just missed to put a washer under the roller counter ...
Julien
