SwanSong
Hi, I've recently had to fix my Tascam 388 myself, with little to no knowledge of the machine. I did fix the problem I had, but in doing so created another one. My old problem was the brake was stuck 'ON' on the take up reel, and the reel wouldn't move or play. I took it all apart, fixed that problem by freeing the brake. It seems that the machine had maybe sat in the heat to long because the brake was stuck, almost melted it seemed, to the cloth of the reel table. Well anyway, I got that straightened out, and put it all back together, and when I put a tape on and hit play, the feed reel broke. The little spindles on the top broke because the feed reel wanted to go the opposite direction it should have. It acted as if it wanted to rewind, breaking the fins on the spindle. I've since ordered a new reel table from tascam, and I'm about to put it on, but I don't want this one to brake the same as the old one.
SO FINALLY, my question is...
What would cause the feed reel to want to go backwards? I could have possibly used a magnetic screwdriver while doing all the work I mentioned above, I don't know if that would have any effect at all. As it sits right now, I can put tape on and play, because the take up reel just pulls it off the feed reel, and the feed reel spins freeley, but I can't rewind, and it makes an awful noise while doing that, which I'm sure is not the best way to go about things.
So, can ANYONE possibly help me? Sorry to write so much, just trying to give a good description of my problem.
Thank you so much to anyone who can help.
