38869420
Member
Hey,
So Channel 7 records quiet. Tested on another 388 and the playback is the same. But playback of a good tape sounds fine on the problematic 388.
I swapped REC play cards 4-7, 6-8 cards and hit the connectors with some deoxit & recorded some test tones across all tracks on the AU388.
Monitor section: 7 plays back quiet and distorted, 8 plays back clean
LR: same as monitor section.
I'm away from the machine, and these tests were a while ago, but i'm pretty sure I swapped the channel cards too and the problem persists.
What else could be the problem, or what's the common reason for this?
Thanks
Thanks
