Se7en-Costanza
Hey Guys,
I have a Tascam 244, everything is completely operational except for one important function.
The Pan controls on every channel only pan to the left, if i pan it right the signal completely attenuates. The right VU meter doesn't move only the left side does (when the pan control is moved back to the left).
This happens on both Cue and Remix monitoring, and as it happens the exact same on all 4 channels, i believe its something to do with the master part of it, or where all inputs sum.
So in bus "sync" recording i can only record on tracks 1 and 3, but all 4 channels record fine and monitor fine on VU meters when you select all 4 Channels to record instead on sync.
Is there a service manual available that someone could email me: nicholas.d.raffaele@gmail.com, or has anyone had a similar problem and know how to fix? I have good electronics knowledge, i just dont want to be poking around without a service manual.
Thanks
- Nick
Thanks
- Nick
