4
4tracker
Guest
Hey guys, I want to try a condenser on my 244. I bought a Rolls Mic Power II. It has two inputs with phantom power. Can I use this safely on a 244 without hurting the preamps?
Thanks.
Thanks.
I don't think they'll be any "safety" issue per-say. More so, just dealing with an unbalanced microphone input on the 244, which would require a balanced 3 pin to 2 pin unbalanced adaptor made by Neutrik or Hosa or similar.
Hosa XLR Female 1 4" TS Adapter Mit 435 loz Mic HIZ Line Transformer | eBay
Cheers!![]()
It would work but there might be an impedance mismatch because there's no matching transformer built into that cable.
Best bet is to try it out and see if there's any weirdness to the levels or abnormal tonality and if it sounds good, use it! If it doesn't, consider the gizmo I suggested earlier.
Cheers!![]()
The transformer adaptor should be at the 244 end of the cable run so that your signal is balanced and shielded all the way right up to the recorder. That connetion should be made between the phantom power unit's output and the tascam 244 via a standard xlr microphone cable. ( this means your current cable would be useless.)
Also, yes, there are dedicated patch-cords which have that transformer built in at the 1/4" jack end. I still have one from back in the day when I too used a 244!
Cheers!![]()
It's an issue for any balanced signal, microphone or otherwise, that needs to be connected to an unbalanced input. Many times you can get away without using the matching transformer if there's no major impedance mismatches. That's why I stated earlier to try it out with what you've currently got on hand and only hunt down the transformer gizmo if needed.Thanks. You've been a big help.
I have some standard cables thankfully, so I can use those.
Do all mics (ribbons and dynamics) require that transformer when going into the 244, or is it just an issue with condensers?
Cheers!![]()
When I had a 246, I used the transformer on every mic I had, even dynamics. I think part of it is not just converting balanced to unbalanced, but bringing it down to a line level.
foggy memory.
