ethyrvalve
Norman Nanoweber
Hi all,
I had a tech set up Tascam 58ob to use sm900 tape a while back and finally attempted to check to see if it was still in alignment today.
I was able to set the overbias to -4db (as recommended in the manual and recommend by rmgi for .25mm head gap machines) and I was able to get the input and repro to match for 40hz and 1khz test tones.
However, for the 10khz the repro meter showed an extra 2db on all tracks. I have the record hi-freq eq trimmer all the way down.
Is this a big problem? If so is there a way to fix it?
Thanks in advance for any input!
