M
MarkP
Hi,
First of all I'd like to thank John & mjbphotos for the feedback and advice.
It's taken a lot longer than I expected to rip out the small room and put things back together.
I have added absorbers to the new large room, but because the room is now square I've run into a new set of problems.
I have placed 6ft x 2ft, 4inch thick absorbers in each corner, added two 2ft x 4ft absorbers behind my speakers and two more the same size on adjacent walls ( used a mirror to position them)
I have also added a 4ft square x 2 inch thick cloud.
Now you'd expect that lot to make a big difference, but it really hasn't because of the shape of the room. I have a massive null around 100hz.
Its so bad if I walk to the centre of the room and bend down so my head is around 4 ft from the ground it completely cancels out.
So, I've experimented with different set-ups. I removed the absorbers from behind the speakers and to the sides and it made very little difference. I then decided to make a monster cloud, so put two pieces of rope
on the ceiling, removed the small cloud and put the four 2ft x 4ft absorbers above my head. You'd think having a 4 inch thick 4ft x 8ft cloud would make a difference... It did, but only by a very small amount.
I've just finished putting together a plan in sketchup that is to scale and I've tried to get the measurements to within a few millimetres of where I have things positioned.
I've also posted my REW results. the measurements were taken in the mix position, one sitting and one standing.
Edit: I can't seem to upload the sketchup files, saying they are invalid? I've posted pong file to look at,b ut will happily email them to anyone interested in helping.
The big question is... Even if I spend thousands on trapping will I ever get this space sounding good, or do I need to go back to the drawing board - Actually, I did play around in sketchup and wondered if it would be cheaper and more effective to just add a couple of stud walls to improve the room ratio. Png's below:
Any thoughts or better ideas than mine would be great,
Many thanks,
Mark
Many thanks,
Mark
