dgatwood
is out. Leave a message.
So at this point, my studio is torn down. I can't get two pieces of S/PDIF gear to lock to each other. System is a quad G5 running Mac OS X 10.4.6 (was running 10.4.3 until about halfway through today's debugging session from hell).
M-Audio FireWire 1814
Presonus FirePod
If I set the FirePod to be the slave:
If I set the FIrePod to be the master:
Whichever one is the slave device ends up making a constant stuttering sound like the frequency is WAY off of 96kHz. The M-Audio doesn't even -try- to sync to the FirePod, pretty consistently showing no sync, then randomly jumping between sync rates.
I guess the next thing to do is hook up the Behringer V-Amp Pro by S/PDIF and see which one can sync to it, then assume the other one is either broken or badly designed.
This setup has never worked correctly with both interfaces since I switched to a new machine and lost the Delta 1010LT as my master clock source. I hate to throw money at a clock generator, though, since there's no way to know if that will work correctly, either. With my luck, I'd just be throwing good money after bad.
Any thoughts? Anybody in the Bay Area with a clock generator they could loan for a five minute test?
Presonus FirePod
- If it gets a message to change to a particular sync rate, it starts ignoring the sync source and the FW1814 gets disabled.
- If it doesn't (normal initialization), a constant note sounds like daaah-daaah-daaah-daaah as though there were gaps in the audio.
- If I set the FW1814 to external sync from S/PDIF, it can't lock to the signal, and thus doesn't show up in my list of inputs.
- If I set the FW1814 to internal sync, the FirePod plays cleanly, but the FW1814 does the stutter thing. This is even with aggregate devices turned on, regardless of whether resampling is enabled.
