B
BLP
Aye i got this aa3 how to get pro studio vocals with no experience dvd for sell $50
I just want settings. dont be a lil bitch.
5db boost at 20hz, wide Q
20db boost at 10khz, narrow Q
6db cut at 11khz, narrow Q
30db boost at 19khz, narrow Q
roll off all the highs above 13khz
Gain - 7
Volume -4.2dbVU
Reverb - room size 90ftx2ft, preverb at mid (about 4.9467) post gain at max.
Compressor - Fast attack (about 7), low threshhold (24.639), post gain at max.
Limiter - Max
Stepfilter - quarter notes hi freq, rest scooped, post gain at min
Widener - 27 feet, post gain =((27feet*average RMS)/(base pan*peak RMS)
Chorus - minimalist...rate 1, resonance 5, post gain -67
This should basically give you the studio vocal sound you're looking for. In fact, this is the goto 'magic' setting for any track. Make sure to do this to all tracks in your mix, and then the master bus, as well as any group or FX tracks you're using, otherwise it will severely bork your vocals. It will also help to add that extra bit of polish if you duplicate each track and reverse the phase on the copy. If it doesn't sound right, it's probably because you miscalculated the post gain on the widener. You may have to adjust your calculation depending on your listening volume. To help you with this, check out some info on nyquist theory.
Once you've done all of this, mix it down, put the finished tune back into your DAW as one audio event, and apply a normalizer set a 4. Don't set it at anything else. All normalizers should be set to 4.
Hope this helps.
I don't want exact steps on TO get studio quality vocals. I want exact steps on HOW to get studio quality vocals. But thanks anyways![]()
While all you pro's are explaining how to do stuff so pro, can you tell me how to play guitar like a pro? I want a Zakk Wylde kind of tone, the soul of Dimebag Darrell, I should be at least as fast as Marty Friedman, and I need to pull off sweeps and rakes like KK Downing. And I don't need a bunch of shit from you sarcastic lil bitches, just tell me which frets to put my fingers on.
-2-
-2-
-0-
This is all you need to know.
ohhhh hey, I want to know that too.....come on guys tell me how.....
pretty please????
You guys are fags, im fucking 13 you shitheads. Not 8 you fucker. And stop talking Austin like i'm not here. You guys are just white faggots.
Thank YouToo bad I DON'T LIKE YOU.
(phew)
looks like you've got a lot to learn little boy.
now run along.![]()
