pisces7378
Hey Guys,
Here are to start out a few questions for anyone that is familiar with these products. But the real thread starts below. so if you are pressed for time... then skip the first 3 questions and go right to question 4.
1. What is the fundemental difference between the Mackie HDR24 and the MDR24? Other than the $1,000 or so.
2. If you have the MDR2496 or the HDR2496, which is not a PC or a Mac... then what do you use a "MOTU 2408MKII Digital Interface" for?
The reason I ask is because I have been trying to think of a way to stop leaning on my PC or Mac so much. I have Logic Audio Platinum and a "good" sound card and all. But I would like to have another option to play with. Stand alone HD Recorders look quite nice to me. But not if I have to go off and buy a ton of $900 audio interfaces and sh&%. because after all that I could have just bought a FAT ASS computer of Mac with a FAT ass sound card system.
3. A digital mixer: (TASCAM D24) Does this thing take my guitar, run the Analog to Digital conversion inside the digital mixer... then feed a digital signal direct into a (PC) hard disc drive? Because that is what the MOTU 896 does via Firewire. The digital mixer looks fucking brilliant! But it is like $2,400.
4. I am going to give you my scenerio and my present equipment list, and you tell me where my biggest weakness is and what you would replace. Keeping in mind that I am in Germany but will be moving home and will have to leave some things here behind... What gear should I abandon in Europe?
Recording: (multi-tracking [24 tracks]) 4-5 piece rock band.
Band:
- Drum set (8 mics going into 8 analog inputs coorisponding to 8 individual tracks for mixing later)
- 2 Electric Guitars (recorded individually or sometimes together) (miced Marshall stack, 1 to 2 tracks)
- Bass Guitar (same miced amp scenerio)
- Vocals (as many as 4 tracks per song)
- Midi (drum tracks, bass tracks, auxilary sounds, strings... 3-4 tracks)
Ok that is my project...
Here is how I have BEEN doing it so far...
Drums: Roland JV1010 Sound Module, w/ midi key controller through a Midiman Midisport 2x2 interface into Logic Audio Platinum 4.8.1 on a Pent III PC. Laying down the high hats, then "overdubbing" the snare, then the kick, then the symbols... time consuming shit here.
Bass: Same scenerio as the drums, except plaing bass lines.
Guitar: Direct recording through my Line 6 POD Direct Box through my M-Audio OMNI Studio breakout box into the Delta-66 sound card into Logic Audio.
Vocals: Same scenerio as the Guitar except with a Rode NTK Valve microphone.
As you can tell I have been doing it all by myself with MIDI and so fourth. But back home in the US I will be micing real drums and using my band to play it all. So I need more Ins. I need to back away a bit from the PC/Midi/sequencing of it all... and start some real mixing. This leads me to think that I need a good and large mixer. Particularlly of the digital kind. (like the TASCAM D24). But I will still be using my PC as the HD recorder and I will still be using Logic Audio Platinum. Is my sound card going to end up being my Akilies heel (sp?)? There is no way that I can squeeze 8-9 outputs out of the Delta 66 in order to propperly mic up a full on drum kit. I do not want to use the mixer to set the levels and then run a stereo signal from the mixer into the sound card on one or two tracks. That would eliminate my ability to adjust the different drum levels later.
Sometimes I would like just some more high hat here and there et cetera. (Is this what the MOTU 2408MKII is going to do?) Is it going to give me those in's and Outs? If that is the case and I am really software stuborned... then i could use the MOTU 2408MKII for ins and outs and use the soft-mixer in Logic Audio with the mouse like I have been. Right?
Anyway, thanks guys, this is still the best BBS.
Mike
Band:
Mike
