I
igorw111
Hello,
I would like to ask for some help, but don't know if this is the right place.
I have a Studer 169 mixing console - 10 channels and stereo master section. These days I'm getting a Telefunken M15a 8 track 1" machine and I have a problem. On my mixing console I can go direct out (from every channel) only via send/return jack. That signal is of course unbalanced (it's not an issue because the cables are 2 meters long), but the signal is -10db because insert point is before fader. Will it be enough signal to go to tape machine? I can make a small modification on my mixer and put insert point after the fader, that would give me 10db more, so then the signal would be around 0db. Would this be enough?
Thanks
Igor
Thanks
Igor
