Stud
  • Thread starter Thread starter alexninh
A
alexninh
Hello :), I was wondering how to make my song sound studio quality? Can someone list down the steps please. Im using Cakewalk Sonar 6 LE with a Samson C01U Condenser Mic. An answer would be greatly appreciated :)
And while you're at it, don't post the same question everywhere.
This has to be an alias just out for a night of trolling.:mad:
:cool:
5db boost at 20hz, wide Q
20db boost at 10khz, narrow Q
6db cut at 11khz, narrow Q
30db boost at 19khz, narrow Q
roll off all the highs above 13khz
Gain - 7
Volume -4.2dbVU
Reverb - room size 90ftx2ft, preverb at mid (about 4.9467) post gain at max.
Compressor - Fast attack (about 7), low threshhold (24.639), post gain at max.
Limiter - Max
Stepfilter - quarter notes hi freq, rest scooped, post gain at min
Widener - 27 feet, post gain =((27feet*average RMS)/(base pan*peak RMS)
Chorus - minimalist...rate 1, resonance 5, post gain -67
This should basically give you the studio vocal sound you're looking for. In fact, this is the goto 'magic' setting for any track. Make sure to do this to all tracks in your mix, and then the master bus, as well as any group or FX tracks you're using, otherwise it will severely bork your vocals. It will also help to add that extra bit of polish if you duplicate each track and reverse the phase on the copy. If it doesn't sound right, it's probably because you miscalculated the post gain on the widener. You may have to adjust your calculation depending on your listening volume. To help you with this, check out some info on nyquist theory.
Once you've done all of this, mix it down, put the finished tune back into your DAW as one audio event, and apply a normalizer set a 4. Don't set it at anything else. All normalizers should be set to 4.
Hope this helps.
