M
Milkfaj
Blue Bear Sound said:Headphones - $2K
two grand worth of headphones!?!?
Absolutely - for multiple uses, and multiple people in bands/choral groups, etc......Milkfaj said:two grand worth of headphones!?!?
lpdeluxe said:Adam P, great post. There's a lot of information there for someone starting out.
Milkfaj said:Steve Albini started very small- recording bands for $200 for all day sessions, and put all the money he made right back into his studio. Now he's got one of the best studios in the world.
Im surprised to see someone whose tag claims "big black and The Jesus lizard" claiming that digital is a better way to go! I understand that it is initially more cost-effective, but im just not interested. even if it ends up only being a hobby studio, id still rather have a real tape machine. In my opinion there has not been any recording in the digital age that i have heard that hold a candle to those great albums produced in the early 90's with tape. I dont want to get in the hole digital vs. analog argument though...
Adam P said:Now I'm by no means saying that you're not capable of formulating an opinion on your own, because thats stupid. I'm just saying that if one of your goals is to be another Steve Albini, you should learn a bit more about what his points of view are.
Milkfaj said:that puts me at about $9000. i may have missed a few things- what do you think?
Cloneboy Studio said:Why get an AKG C1000 when you have 2 SM81's? The 81's are way nicer small diaphragm condensers for high hat (I'm assuming that's what the stray SDC was for).
You can get superior Soundcraft 24 channel 4 buss mixers used than what I'm assuming you're getting. Try 600 bucks for a Soundcraft 400b.
Cabling and snake alone may get to be 1200 bucks without a patchbay... unless you're going Hosa (not recommended).
eek:
Milkfaj said:Ii also belive it was you that suggested an analog front with a DAW in the background? well, i wasn't planning on mixing down to analog, i should have made that clear. I want to get a better soundcard for my computer and use that for mastering.
Milkfaj said:Who has heard the album Rembrant Pussyhorse by the Butthole Surfers? I think thats a great sounding album and it was recorded with shit equiptment and from what i understand, very limited know-how. Ill admit my tastes are on the ugly-side...
Milkfaj said:I think that the creativity of the engineer is much more important that his budget, and i imagine that most of you would agree with me (to all of your credit) being that you are engineers. Its the person using the tool, not the tool itself. thats my philosophy at least.
Hosa is a company that makes cheap cables. Normally, you would use balanced cables between the board and the recorders (depending on the inputs of the recorder) an 8 channel snake of any quality will run you at least $120. For 16 channels you will need 4 of them (2 in and 2 out of the deck) If you run everything to a patchbay you will need 8 (plus the patchbay)Milkfaj said:i'll admit that i dont know much about cables. i dont know exactly what Hosa is. Im not going to use a patchbay right away. Ive heard a lot of different things about cables and if someone could straiten me out id be very greatful. I know what XLR is and low and hi impetance (impotent?) but i dont know what TSR refers to, i just know its a 1/4" jack, right? What kind of cable would i use to wire my mixer to my recorder? Insturment, Speaker, Patch cable, XLR, TRS, none of the above? i know cables are going to be expensive, so if i run out of money, ill just ditch a few SM57s...
Milkfaj said:I plan on putting together a pro-quality studio, but ive never worked with anything more complex than a four track, SM 57s and a Computer with cakewalk. Im planning on using a Tascam MS-16 or MSR-24 and a 16 or 24 channel Mackie Mixer. My main question is weather I plug my Mics into the Recorder first and then run it though the mixer for mixdown (this is what I assume to be the case) or if i go through the mixer first. If i plug into the recorder first, do I need a preamp for each mic or just for the ones i want to sound really good (i want to get a Shure KMS44 and a JoeMeek compressor/preamp) but to I need a seperate pre for all Five SM57s too? also, where to compressors fit in? do i run them in between the Mics and the recorder, or in the effects loop of the mixer?
please tell me what you think of this hypothetical setup. Any advice would be much apriciated. Im on a budget of about $8000 and I want to stay as analog as possible. thanks!
Maybe you should have read the posts - because acoustic design of the space was one of the FIRST things mentioned.............Outlaws said:I am not going to bore myself with reading the all the replies that have been giving so far because........ blah blah blah.....
Blue Bear Sound said:Maybe you should have read the posts - because acoustic design of the space was one of the FIRST things mentioned.............after I shoved the talkback mic up my ass.![]()
Yes - it IS too bad -- otherwise you might actually learn something..........Outlaws said:Too bad my scroll wheel is set to U turn after 5 full rotations to pass all the bullshit.
