gentlejohn
Budget about £200 (tops!) Any recommendations?
Give Van Amps a call. They can do a racked reverb unit for you.
Check out the Rack-Verb in the link below (on the left).
Van Amps Custom and Limited Edition
I own the tweed VanAmps Sole-Mate reverb, and about a year ago I had them also add the Pedal Deck to it, and modify the power option on it a bit. The Sole-Mate is my main unit for use with non-reverb amps, and it sounds quite good.
I'm not sure how well their Rack-Verb would be for a mixing application, but I see no reason why it wouldn't be a good option for you, and since they do these more as a Custom/Limited Edition build, they can make it fit to your needs. The quality on their stuff is quite good. They also do International sales. The floor version Sole-Mate is in the $350 range....so the racked version might be just a bit more due to the bigger rack case, but the guts are probably the same.
Here's some other brand/model options from eBay:
Stereo Spring Reverb | eBay
Actually, if I can keep this subject going for a bit longer now that we're talking about it, how good are the consumer-brand stereo units (Pioneer, Sansui, etc) for analog post-production? I've come across a couple now and then and have wondered if I should add it to my setup.
Digital reverbs became so good at emulating plates and springs and so long ago that I’ll never use real plates and springs again.
