		seamus
Hi all,
I'm a newbie with recording, and was wondering the best way to do something. I am using the Omni Studio w/Delta 66, Sans Amp DI for bass, SM57 for guitar, and n-track for my software solution. The recordings themselves sound good, I just need to mix them properly.
When I record my bass or guitar tracks, I'm basically just recording a mono track to one side, either left or right.
Is there:
1) A way I can record so that my output would be recorded to both the left and right sides simultaneously?
or
2) A way to use the software to do the same thing once I have a mono track already recorded? In effect, just doubling a mono recording so that it plays back from both the left and right sides?
Since I am using a DI box for bass and a mic for guitar, I am plugging into only one preamp at a time on the Omni box(usually #1 on the left side). Seems that the n-track monitors only detect a left side signal when I record, which seems normal to me given I am plugging into only one input on the box.
Is there such a thing as a XLR Y-cable for doing what I want to do? I'm unsure if the best way for me to go about this is to use a certain cable, the hardware, or the software to achieve a recording with the same thing coming from both speakers?
I also do not know if this is just a matter of checking certain settings in N-track as I am still uncertain of what many of them mean. What's strange to me is that while monitoring through the box as I'm playing, it sounds like the output is coming through both the left and right just fine, but the program only records the left side.
As you can see, I'm kind of lost with all this and feel like a dope. Is this the wrong way to go about recording altogether? Are there other things I should try?
Thanks for any help!
Is there:
or
 Is this the wrong way to go about recording altogether? Are there other things I should try?Thanks for any help!
