Splitting mic cables and phantom power.
  • Thread starter Thread starter spankenstein
spankenstein
For recording live shows I would like to just intercept the mics that the FOH is using anyway.
Can I use just a Y cable? If so... what about phantom power?
If I'm looking at this the wrong way could someone please point me in the proper direction?
You can't use Y-cables. They sell dedicated splitters for just that purpose - that's what you need.
Maybe too obvious but have you got a spare aux on the FOH desk? You can get get a totally independent or fader-dependent (pre- or post-aux) depending on your desk.
Thanks! Now I know what to look for.
I want to get each mic seperate. I don't want to count on the inserts being free.
Cool. Let us know if you find any good gadgets .. one can never have enough!
But then he's stuck with the EQ from the desk.......... (sure - pre-post, but that doesn't usually bypass EQ)
The proper way, as I mentioned, is to use a splitter.......
I know! I was just making a suggestion. I've heard reasonably good recordings made of aux sends (and some dreadful ones too ... ). Of course it only works if you have a sound guy who doesn't mind sharing the desk whilst you work on different mixes.
Found this site: http://www.whirlwindusa.com/tech06split.html
Very informative along with a nice little wiring diagram! I think I'm going to be doing some splitter making.
The parrallel splitter is just a Y cable but since I have NO idea knowing what I'm going to be working with I'm going for the transformer isolated one.
I have also heard some good off the board recordings... but I don't want to be held hostage by a potentially bad FOH.
yeah sure - i guess i was kinda assuming a fixed venue or gear list! The article looks interesting, I think I'll give it a read and maybe reach for the soldering iron.
Completely mobile is my goal. Everything in one or two small racks of equipment.
I hope it's a really small band or you have a big budget. Splitting 20 mics isn't cheap. The ART PhantomIII is one of the cheapest splitters with phantom power. They will split two mics for $40 (that is dirt cheap for splitters). Not sure if they are any good or not. You could get a bunch of them and rack them. Luckily most live mics are dynamics so you may only need 2-4 channels of phantom power. It's often just the drum OH's that are condensors.
Sonusman made a 24ch splitter with transformers and it cost around $8k as I recall.
I haven't priced the transformers yet but I'm lokoing at around $500 (estimate) to do a 16 mic split.
Wow... transformers are expensive! Whirwind ones are $40. Jensens are $50.
For 16 in 32 out (16 isolated 16 direct) it's coming up to around $950. Definitely more costly than I was expecting.
