SPECTRALIVE V2.0 Released
  • Thread starter Thread starter crysonic
C
crysonic
Hello everyone,
SPECTRALIVE V2.0 Has been released, incorporating many new additions including updates and important fixes.
The price remains the same at US$34.95; previous customers can upgrade to V2.0 for only US$10.
Upgrade and purchase at www.crysonic.com
BUG FIXES AND COMPATIBILITY
- Pentium CPU utilization increase due to De-Normalization, this caused the
CPU usage to increase for no reason and it would need to be removed and
re-inserted, this issue is now fixed.
- Sonar hosts such as Cakewalk and Project five had the Audio cut-off
intermittently has been fixed. The problem related to a GUI configuration.
- Automation feedback is more robust and accurate.
- VU meter caused some delay and audio artifacts in some hosts, it has now
been fixed.
- FL Studio unpredictably slowed down, causing 100% CPU utilization if two
instances of Spectralive were enabled.
- Turning Spectralive on and off when the Vitality dial was above zero
caused the levels to increase even when the Mix setting was at zero.
- Turning Spectralive on and off when the Mix dial was above zero caused the
levels to increase even when the Vitality setting was at zero.
- Minor issues when using Abelton Live fixed.
- Tracktion 2 no longer causes intermittent internal errors.
- When all the Dials were set at no processing and the input dial at
maximum, the level was 3 dB lower and when switched off the level increased
by 3 dB.
NEW FEATURES AND UPDATES
- Global Spectralive behavior can now be selected with a new GUI based on
the source Audio material approximate frequency range. There are 12 settings
and each has been statistically calibrated against common Audio test
sources. These settings affect the way Algorithm, Process types and stereo
separation amounts to correctly keep the output Audio in phase dependent on
the source signal. This can be tested with a vector oscilloscope, previously
some settings would cause 2-4 degrees phase shift to the right. It is
important to point out at this stage that it is meaningless to test
Spectralive with a single frequency audio source such as a 450Hz sin wave;
this is due to the fact that Spectralive works by looking at a broader range
of frequencies, phase relations and the harmonic content in the source audio
material.
- P-FINE allows you to rotate the phase of the output signal by small
amounts, allowing the user to correct minor phase misalignments.
- Main, Vitality, Mix and Stereo dials now have numeric displays where the
exact value of each dial can be seen.
- Pressing Ctrl while adjusting the dials will increment or decrement their
value by finer amounts.
- 64 custom presets including a further 64 default user assignable preset
slots.
- The vertical dial version has now been incorporated in to the same GUI
allowing you the option to use what ever you feel more comfortable with.
- The stereo section has been updated to provide much better results that
are smoother allowing you to set much wider separation if required.
- The overall quality of the Spectralive process has been updated to sound
much smoother over wider range of uses.
With kind regards,
crysonic Australia
www.crysonic.com
Where's the new feature that allows us to turn off your spamming of the forums?
G.
G.
Hopefully in version 3.0
crysonic said:
Hello everyone,
SPECTRALIVE V2.0 Has been released It is important to point out at this stage that it is meaningless to test.
use what you feel more comfortable with.
Well there you go. Direct quote, his words, I added nothing. I simply applied my special spam filter.
-RD
  • Like
Reactions: LfO
