Wow. Long post. I need to get a life . . .
joedirt said:
Chessrock, good, helpful stuff. Actually I've got the the bottom end sounding good now. Do you have any carving tips for the midrange? And what about topend? Does rolling off or cleaning up high end stuff help?
As far as the midrange stuff goes, you're probably going to have some conflicts going on between the vocals and electric guitar. It's invevitable, but it's not really a bad thing. The same principles will apply here.
When working with vocals, keep in mind that they are usually the focal point of a song, so it's okay to let them hog up a lot of the midrange. Let them be stingy. Voices sound much fuller when they are able to resonate a wide, balanced freq. spectrum, so do as little cutting as possible here.
With this in mind, what I am about to say will seem to contradict things, but it really doesn't: In order to make the voice sound fuller, I usually look for the most prevelant frequencies that stick out in the spectrum analyzer, and then eq them down a few decibles. What that will do is make the "spectrum" of that voice wider by "leveling it out." Now the frequencies in that person's voice that normally aren't as prevelant can be heard better. Remember, though, that your ears should be your final judge on this. Sometimes these "main frequencies" I'm telling you to cut could actually sound better if left alone. Maybe they give the person's voice it's unique character, or they help it cut through the mix better.
There's not much to worry about with the guitar and voice. They sound sonically different enough that there's no real danger that you won't be able to distinguish the two. Just do your best to eq down any frequencies that tread too heavily on the voice's turf. Also beware of large freq. jumps durning times that they do meet on a common freq.
What's most important for the guitar is to cut out some of the bass below 150 hz, and maybe even 200. That's the bass' territory, so think of the two as almost one instrument. Let the bass make the guitar sound fuller. Johnboy Walton said that in another thread, and I think I'm going to steal that one from now on.
The guitar is always the easiest thing to hear anyway, and it gets enough help from the bass, so feel free to carve away on it if you absolutely have to.
Can you tell I'm a bass player yet? Another approach I might take is to mix down just the music itself first, and then carve out a space in that for the vocals. I rarely have to do this, but sometimes find it necessary when the voice is having a real hard time cutting through.
The only danger you're going to run in to on the high end are siblant vocalists and/or swooshy or harsh cymbals. The best cure for this, actually, is preventative medicine. Just use good microphones and be happy during mixdown when your life is made 100 times easier. Actually if YOU USE THE RIGHT MICS and put them in the right spots, you can pretty much DISREGARD THIS ENTIRE THREAD!
A lot of cheaper models like the Rode NT1 or the Marshall 2001 have a serious bump in the higher freq's around 12khz. This can sound really nice on some things but really bad on others. It can sound fine on acc. guitar. It can awesome on some vocalists. Or it can sound really AWFUL on more siblant voices. In my opinion it ALWAYS sounds BAD on drums and/or tamborine (makes hi-hats and tambo sound like fingernails on a chalboard). Harsh preamps can have a similar effect.
If you abuse these types of mics in that fashion, I recommend doing some serious gouging out around the 12 khz range on those tracks. Or you can pull out
the microphone modeler and model it to an earthworks or an octava mc012 . . . something with a flatter response in the higher frequencies. Ideally, you should use the behringer ecm-8000s, oktava mc-012's or Marshall mxl 6003's when tracking drums, acc. guitar, or tamborine, anyway.
There's no excuse when you can get them as cheap as they are these days.
So to FINALLY answer your last question: If you track correctly and use good mics and neutral-sounding preamps, then you should be able to let the high-end get as loud as the rest of the mix. If not, then it's better to cut out anything that may sound gritty or that will tire your ears out over time.
On a final note, keep in mind that the area where our hearing is most sensitive is going to be around 2,000 to 4,000 hz. It's okay if there is a dip in this region, because our hearing will make up for it. The bulk of a song's energy will often be around 65 - 80 hz (bass drum), and 200 hz (snare). It's okay if they peek a little louder than the rest of the mix. The midrange should have the most consistant action going on, while the high end is there to provide crispness and air.
