Speaker Monitor fix
  • Thread starter Thread starter jli
J
jli
it needs more cowbell....
My oldest boy got into my mixing room and pushed the center of the horn in on one of my KRK V8 monitors. AAAAAAAARHHHHHHHHHHGGGGGGGGGGGGG! I took it apart and It doesn't appear that I can push it out from the back side. Any suggestions on a fix?
vacuum hose on outside, to suction it out. sounds like it may work.
Yeah I've heard of cones and dust caps being sucked out - hoover sounds like an idea.... let us know if it works!
I ended up using clear tape for the fix:
gearslutz.com/board/low-end-theory/604714-speaker-monitor-fix.html#post6571057
but I think the vacuum would have worked too.
I've used a fine bit of wire. Make a little hook on the end, poke it (gently) through the cap, and pull. With luck the dent will pop out. With luck you won't see the hole.
