My oldest boy got into my mixing room and pushed the center of the horn in on one of my KRK V8 monitors. AAAAAAAARHHHHHHHHHHGGGGGGGGGGGGG! I took it apart and It doesn't appear that I can push it out from the back side. Any suggestions on a fix?
I've used a fine bit of wire. Make a little hook on the end, poke it (gently) through the cap, and pull. With luck the dent will pop out. With luck you won't see the hole.
