Speaker Cabinet Wiring Nightmare!!! Help!!!!!
  • Thread starter Thread starter RightOnMusic
RightOnMusic
RightOnMusic
asshat
so here's a diagram i drew of how my cab is wired. each speaker is 8 ohms... the jacks are setup so that when a cable is plugged in, it breaks the connection between the right and left side of that jack (leaving the right side active and the left side dead).
obviously, the 4 ohm jack doesnt work and the 16 ohm jack only gets sound out of 1 speaker. i emailed the guy who built the cab, but he hasn't gotten back to me and i need this cabinet to be in action by wed....
can anyone make sense of what i need to do to this thing to get BOTH the 4 and 16 ohm jacks working?
Why don't you just pick an impedance and wire it one way? (I tried to figure it out in my head, but I broke my brain doing that)
because sometimes i use a bandmaster and sometimes i use an orange. (4 ohms and 16 ohms respectively)
I don't see how you could figure it out without knowing how those jacks are internally wired. It looks like the one on the left has its tip and sleeve shorted.
You don't have both those amps plugged in at the same time, do you? ;^)
you should've passed on marriott and stayed at a holiday inn express...
lol, no, they're not plugged in at the same time. on the diagram, the bottom is tip, top is ring.
maybe this is a perfect opportunity to put backup plan gr3 into effect
yeah, need to use the orange at a rehearsal on wed, and need to bring the bandmaster to buffalo to sit in with schleigho. need a grand and change for a new macbook before the GR3 takes a front seat.
Don't quote me on this, but remove the one wire from the 4-ohm jack to the positive lead on the speaker '+' lead as so......
If it works, thank me later. If it stays screwed up, just remember what you paid for this great advice ;). With a good DMM you should have it solved in minutes. With just a piece of paper and real brain work involved, we're all in trouble, son.
no, don't remove that wire -
just disconnect it
from the positive speaker lug
and connect it to the
negative lug
of that same speaker
i think that will fix it
Ah! I think it might work even 'better' going to the negative lug of the other speaker! But either way, he should have it solved in no time flat.
It would be easier to just use two shorting jacks.....
no
the 4 ohm jack
would still have
no connection to
the first speaker
with the cable plugged in
OK, I know this is late, but it's right. This is assuming your jacks are either actual Cliff jacks, or jacks which have an identical layout, and it is also drawn with the jacks laying with the solder terminals facing up. This puts the switch terminals on the left side.
Oh, and if you can't be bothered, just wire the whole thing for 16 ohms. You'll loose some power with your 4 ohm cabinet, but you won't hurt it.
You just had to post a switch logic question didn't you? I can't keep away from them - my mind just works that way.
Light
"Cowards can never be moral."
M.K. Gandhi
What is the internal wiring on those jacks?
When you plug them in, the one on the right gets lifted up to break the connection with the one on the left.
At least, on the two Cliff jacks I pulled out of my amp to figure this out (they are just there to fill the holes in the face plate - I've modified that amp to the point where it barely possible to see where it started, and I now only have one input jack, which is all that I need).
Light
M.K. Gandhi
Thanks, but that wasn't what I was asking. I would like to know the signal paths between the six pins inside the "black box" of the connector. Are they TRS or just TR? Are there make/break contacts inside? Between which pins?
When nothing is pluggedin, they are connected straight across. (tip left to tip right, sleeve left to sleeve right) In this situation, the ring is not used. As soon as you plug something into the jack, the connection across the jack is broken.
Ah. The bottom two are a break connection for the tip, the middle two are a break connection for the ring, and the top pair are a break connection for the sleeve. In all cases, the right side connector is the one that stays live.
Light
M.K. Gandhi
