I've got an M-Audio SAM that translates one spdif input to all eight ADAT outs: 1-2, 3-4, 5-6, 7-8 mirrored across the board... and will also sum all eight ADAT inputs to the stereo SPDIF out (gain and pan on each ADAT channel)... I don't use it often... but it can be a life saver
Thanks, but what I am looking for is something that takes 4 spdif inputs (not 1) and muxes them to adat {1,2}, {3,4}, {5,6}, {7,8} respectively.
Specifically, I have 4 effects units that product spdif output, and I want to be able to generate a single adat stream from those outputs. I need this as I have an available adat input to my board, but I do not have 4 available spdif inputs.
Something like this *should* exist at a reasonable cost
The Alesis only supports one SPDIF input and output... It's a bit misleading since their documentation states 4 physical SPDIF connections... 2 RCA (in/out) and 2 Optical (in/out). Optical and RCA connections are shared.
You'll find it a lot easier to locate a unit that takes 8 analog inputs and then outputs to ADAT. So you might want to consider coming out of those fx boxes via their analog connectors instead of SPDIF.
