Giganova
gimmi your mic!
wassup?
I had my first female vocal session last night. I used a Sennheiser MD441 with pop-filter, plugged into a Focusrite Green channel strip, with slight compression (2:1) & de-essing, fed into my pc running Logic 5.5.
The female vocalist wasn't that great, to say the least, so after 4 hrs of recording we called it quits. Spent the rest of the night trying to make the vocals as "sparkling & fat" sounding as possibe, using some effects. Here's what I used:
o inserted more compression to add dynamics.
o a touch of a stereo pre-delay made the vocals sounds "fuller"
o reverb
o doubling of some parts of the vocals to emphasis them (same pitch & style of singing)
o in a copy of the same track, I added 40% of a pitches shifted take. I shifted the signal 2 semi-tones up to make it sound in tune.
Does that make sense to you? Should I eq and boost some frequences? What's a typical setting for eq? Any other ideas what I could do to improve the vocals? I wish I had an "auto-tunes" to play around with, coz some parts of the vocals are slightly out of tune, but don't know where to get a plug-in auto tuner.
One additional question: even though the Focusrite Green pre was set to max, the signal was only about -4 to -8dB if the singer was very close to the Sennheiser 441 mic. That's not a strong signal compared to condenser mics I used before. Is this low signal inherent in the dynamic mic?
I know that's a lot of questions, but I have to "save" the session.
Thanxxx!
o reverb
Thanxxx!
