Sorry to be all over the road here.. im a little stressed atm
No prob, me too.
Ok, here is the deal. Since you didn't tell me what I asked I can't guarantee the maximum performance of this wall given certain conditions as sharing the same wood floor, common ducting, etc etc. However, here is something you need to know.
If you were to build a wall in front of the existing wall, with ONE face sheithed with drywall, what you would end up with is a THREE LEAF system. Not good. In fact, it could be worse than doing nothing in regards to low frequency transmission, which for all intents and purposes IS the predominant frequencies that transmitt through residential partitions.
So, this is what you need to do. It sounds to me like this is a rental, no? If so, it is highly unlikely that you could actually do what NEEDS to be done to the existing wall. Which is REMOVE the drywall on your side of the wall, PRIOR to building your new wall. See the illustration attached.
IF you could do this, and fill BOTH wall cavities with insulation, and then drywall the new wall on YOUR SIDE ONLY!! This would create the best you can possibly do under the circumstances as it would create a double wall TWO LEAF system. In fact, IF you were in a position whereby you could remove the existing drywall on your side, you could could then beef up THEIR leaf, by cutting drywall to fit BETWEEN the existing studs. TWO LAYERS THICK. You could ether use adhesive to adhere it to the back of THEIR drywall, or use 2x2 cleats to hold it in place, while caulking all joints of both layers. The point is to leave NO AIR between the back of their drywall leaf, and the layers of new drywall within the stud cavities. This would give a THREE layer leaf on their side, and a 3 layer leaf on your side. There is one other thing here. You NEED to position the new wall to gain the MAXIMUM depth between LEAFS that you can afford to loose in floor space. It is the mass of the leaves, and the airgap distance
that will determine the LOW FREQUENCY transmission loss. In other words, that resonant frequency point which below transmission occurs. The lower the better.
However, IF this is something you can't actually do, then the best thing you can do next, is drill 2 or 3- 4" or 5" holes in YOUR SIDE of the existing drywall. This will vent the airgap to THEIR leaf. Do this at each stud cavity, prior to building the new wall.
However, if this is STILL undoable, your only recourse is to beef up the mass on the new wall to at least 3 layers. Your low frequency transmission may stay the same or it may increase, I don't know, but mid and high frequency transmission should improve dramatically.
Once you decide which solution you can achieve, let me know and I will tell you more details pertinent to the solution.
As to price and materials. Figure the same material for framing via 2x4, but depending on which solution you chose, figure at least 15 sheets 4'x10' 5/8" drywall. If you CAN pull the existing drywall off of your side, add another 9 sheets to the list. And double the insulation linear footage to 300'. Well, I hope this helps. I'm really glad you posted that enlightenment. Whew!
Be aware though of my previous caveats regarding flanking paths. Also, don't build anything till you come back and let us know you have the materials. There are a few details I don't have time to tell you about right now. Well, good luck with Home Depot. Don't let them sell you any SOUND BOARD or anything like that. Oh, you might check on a roll of "sill foam", which is a product for sealing the plates before fastening them down. Otherwise acoustical caulk, or butyl rubber caulk will have to do.
Another area here is what the ceiling is like. We may have to do something here. Anyway, later
fitZ
