soundblaster question
  • Thread starter Thread starter playdrums
P
playdrums
does anyone use creative soundblaster audigy2 soundcard? i am asking beacuse to record i use a samson mdr6 hooked into the line2 input of the front interface and i do not know what out put to use to go from the computer back to the mixer to mix while i play back the recording if anyone knows or can understand me (i dont know if im making sense) pleasee respond thanks
I use the audigy 2 zs platnium........ unfortunately I have never had the need to send a signal out of my computer and into something else, everything I do is with HomeStudio software, but I'll try to help. I guess for starters what size jacks and plugs will you being running into on your mixer?
You can also reference the help topics in Creative, look under PLAYING/ RECORDING MUSIC. There you should find a chart for a variety of different configuration.
I hope for the time being this will get you started, in the mean time I'll try to research it more
Good Luck :D
Chris
sound balster question continued
the input for my mixer are left and right audio jacks (white and red) that is what im using for the output and that goes to a 1/2 inch jack in the sound audigy front interface, i just cant figure out what spot is a input in the computer and how do i set5 that up? thanks a lot for your help chris!
-kent
Kent,
Like I said before I'm not sure of the best method but why couldn't you run from your 1/4" stereo headphone jack into the mixer using a stereo 1/4 to stereo RCA cable. you can control the output level into the mixer that way as well.... just a thought for now. I know you can use the 1/8 out on the back clip.
Chris
I also Use The audigy 2 i go into my computer with the aux 2 input which is the rca's (left- right) i go from my tape out on my mixing board and come out of the card from the headphone jack back to the board with cable 2- rca's with an 1/4 adapter into 2- rca's to the tape in if your mixing board is equipped with tape I/O
lespaulman01317
Is the extraneous HTML *really* necessary???? It's fucking annoying as hell.......... :rolleyes:
*::I LIKE IT::*
Actually, it's a little annoying isn't it?
