Sony stereo speakers
  • Thread starter Thread starter reocrding100
R
reocrding100
Hi , I have an old pair of sony stereo speakers and an amplification system that came together . I still didn't start using monitors and I thought that using them would be a fine start . Can I plug those to my M Audio Fast Track 8R ? (they are really old ) , how ? , is their a certain cable that I need to buy ?
Thanks
Yeah, you can use em. I don't know which speakers you are considering. Their bookshelf speakers would generally be the better choice as their floorstanding speakers are about the most inaccurate speakers I can think of. The bass is unbelievably hyped and any "mix" you might capture off of these would not translate very well, if at all, to other systems.
Ive gone down this path as well and, many many years ago, when I transitioned from my pair of Sony bookshelf speakers to a set of decent monitors (EV MS802), it was literally night and day. While I could get decent mixes off of the Sony's, the EV's made it so much easier and faster that I kicked my self for not trying monitors earlier. My mixes were of a much higher quality because, well, you can't mix what you can't hear. The detail that was missing from my earlier mixes (nuances such as string/fret noise, key clicks on horns, even the breathiness of a vocal) was suddenly revealed with monitors.
We can mix, theoretically, on almost anything as long as we know how those mixes translate and how to compensate for the speaker systems shortcomings/inaccuracies. But, that doesn't mean it's an easy or worthwhile process when, even a inexpensive set of monitors, can make the mixing process much more efficient and effective.
As for cables, I'm assuming you've got 1/4" outs on the interface and the stereo amp has RCA inputs. If so, the just get a pair of 1/4" to RCA adapter jacks. http://www.audiogear.com/cgi-bin/shopper.cgi?key=Adpt-QMFRCM&preadd=action
Run your 1/4" cables out of the interface and plug the adapter into the amplifier.
Hi
Thanks , you helped me a lot ! . After reading your post im considering buying monitors , what would you recommend (50-150 dollars ? ) I have seen the BEHRINGER MS16 and the M Audio AV series , but is there any real difference between buying those or using my "desktop " speakers ? , because on this budget most of those monitors are meant for your computer .
Thanks
Thanks
Where are you located? I'd be surprised if you couldn't locate some decent used monitors somewhere. I wouldn't recommend either of those speakers as they really don't give you anything that you don't already have with the Sonys.
Hi
Hi , im located in Israel , thanks for your advice , I will check if they sell the monitors you recommended here .
Thanks
Thanks
Israel? LOL...sorry cant help you much.... I've got about zero contacts over there! :D Good luck on your monitor search...let us know what you find.:cool:
Hi , I checked again and saw the Behringer MS20 , the price is fine , do you know if it's worth buying ?
Thanks .
While they aren't optimal, they are certainly a step in the right direction. They seem to review pretty well. Probably a pretty good first monitor for some lighter projects. They'll likely be a little light on the bottom end with < 4" woofers tho, so keep that in mind. I don't know what styles of music you'll be working with...they're not a great choice for anything with a lot of bass info.
