Something NEW, not GNU
  • Thread starter Thread starter The Green Hornet
T
The Green Hornet
For all of you who know that gunk does accumulate on 1/4 plugs and the insides of where 1/4 inch plugs go, here is a neat little cleaning tool that utilizes interesting technology.
Name: Conductool by Synersonix
Purpose: Cleans 1/4 inch plugs and 1/4 inserts
[they also make a unit to clean RCA and XLR plugs]
Cost: 19.95 @ Musician's Friend [haven't seen it in any other catalogs yet.]
Info: "Insert the mono or stereo 1/4 inch tip of the cable into the small hole in the back of the CONDUCTOOL handle. Insert in/out a couple of times."
For inserts: Use the tip of the unit that resembles a 1/4 inch plug and insert and remove a couple of times.
Non-poisonous. Lasts 1/5 years depending on use. Each treatment lasts 90 days.
I just got one and it sure is easy to use and I think very beneficial for a good clear signal.
As the literature says, the tool is like a "molecular toothbrush."
Green Hornet
Why not a cloth towel and some cleaner
Why can't you use a cloth towel and some cleaning fluid?
Yo-Yo-All:
I'm sure you could use cleaning fluid and a cloth. Or the tongue of a dog or cat.
However, none of the above have the molecular construct of easy cleaning and making for a better conductive surface for induction and production of mellifluous sounds rather than cacaphonous shrill from the depths of ambiguity.
Happy St. Patrick's Day
Green Hornet:D :D :D :p :p :cool: :p
Just swallow some WD40 and stick the plug up yer arse.
Yo Roadkillthat'sbeeninthesuntoolong:
WD40 doesn't conduct signals. If you use it, it's because you're buying oil from Bush down Texas way.
Do you still use a wire recorder?
Cheers,
Green Hornet
PS RAT Man: You've got more class than that!
