A Reel Person
It's Too Funky in Here!!!
Fostex has a lot of plastic mechanical components,...
where the Tascam counterparts would be metal............
fred s. said:Where would you guys look if you were buying? Other than ebay, I've also gone through local paper and graigslist. I'd like to pull the trigger on this sometime n the next week.
jpmorris said:On mine the power supply board went funny which caused the capstan to slow down sometimes. I took the board out partly to take voltage readings, and after that it started working again. Something may have come unseated during its journey
..............................superbeatballer said:Is this good shipping-wise?
http://cgi.ebay.com/Teac-Tascam-80-...6QQihZ011QQcategoryZ41480QQrdZ1QQcmdZViewItem
fred s. said:Thanks for the additional info.
PS: I think I'd also be interested in 4-track recorders using 1/4" tape.
Muckelroy said:Watch out for the Teac A-3440's. Though they look, and sound WAY COOL as they have a sorta 70's EQ bump to it, their electronics are a bit noisier than the other aforementioned 4 track models.
-callie-
jpmorris said:One point I forgot to mention: You're talking about digitizing with a 2-channel soundcard, aren't you? That's not generally a good idea since the tracks will drift out of sync as the machine will never play back twice at exactly the same speed. You may find you have to do some fancy footwork in N-track to get the tracks to line up again, but it will depend on the length of the song and how stable the machine (and soundcard) are.
Ideally you'd want to get an 8-input soundcard and digitize them all at once, but it will probably cost the same as the recorder. That reminds me : I must get one of those cards myself so I can take safety copies of my master tapes.
fred s. said:Hey I gave this some more thought...would the Delta 1010 LT be a good card for this? Any other cards I should look into to use with n-track?
ps: today I'm going to be checking out a local Tascam 388 I found. The guy said a couple VU Meter lights are out. Is this an easy fix?
Also found a pretty good Fostex model 80 for about $200.
jpmorris said:Tascam: Don't know about the disassembly to get at them, but changing the bulbs isn't too hard. (Currently wondering whether to put christmas tree lights in his B77)
The Delta 1010LT is what I'm vaguely looking at for backing up my master tapes. If you're just doing a 2-track mixdown to the PC, you'll only need a stereo card, the Delta 24/96 thing, perhaps?
It's often a good idea to have the AD converters outside the PC, although it gets more expensive. The full version of the 1010 is not cheap, even on ebay.
For 2-track final masters I use a USB Transit. It's not without its problems, and it seems to work best in Linux (it was truly useless on my Windows setup) but it does the job.
fred s. said:today I'm going to be checking out a local Tascam 388 I found. The guy said a couple VU Meter lights are out. Is this an easy fix?
