W
walters
What does the solo button function really do inside a console?
Does it Isolate the audio track? how does it Isolate it?
I think you're confused.cellardweller said:In higher end consoles, it initiates the EVH circuitry.
This improves the milky smooth nature of guitar solos, and really brings the creaminess out of even the most curdled of players.
walters said:What does the solo button function really do inside a console?
The Ghost of FM said:... Fromage Intolerance Button?![]()
You're obviously cheating and plagiarizing in that I read the exact same info in the AES and NAB reference handbooks!BRDTS said:What does the solo button function really do inside a console?
As mentioned, you've got the whole concept confused.
During mixdown, at any point where a guitar solo or sax solo..or any kind of solo is coming up in the recorded song, you have to push down all the solo buttons on the console. A good engineer can push all of them down fast...in time, before the actual solo starts. The purpose of these buttons is to let the console know that an important solo is coming up...thereby routing the signal path into the cleanest circuitry that the console has. Usually the analog part where there are lots of wires. By pushing down all the solo buttons on the console, this guarantees that all your guitar/sax/harmonica/hi-hat solos are crystal clear.
Some consoles have hundreds of solo buttons and several larger studios have part time solo-pushers who help the main engineer. It's a great way to get into the biz..you might want to consider applying for this exciting job at one of your local studios.
There are also some interesting uses of mute buttons in professional recording. Some engineers have found that when needing to mute multiple tracks during mixdown, it's much more efficient to simply pull the console power plug out of the wall rather than using mute buttons. Try it...no matter what the brand, the signal to noise ratio of any console goes way way down when unplugged from the main power.
heh heh
I'll take a short serious stab at this too.walters said:What does the solo button function really do inside a console?
Yes, exactly!walters said:If i push down all 24 tracks solo buttons those it BYPASS a circuit in the console or recording DAW so its more "isolated and cystal clear sounding"?
The solo fucntion must have a different routing? to bypass a circuit?
and go straigt input the recording medium analog/digital
The solo function has different MODES what are the different solo MODES?
that engineers use?
walters said:The solo fucntion must have a different routing? to bypass a circuit?
walters said:The solo function has different MODES what are the different solo MODES?
that engineers use?
walters said:press a PFL/AFL/SIP solo button
PFL mean? or stand for?
AFL mean? or stand for?
SIP mean? or stand for?
.... here's my guess-shot:walters said:soloing DOES affect main output signal (not (or not just) monitor output).
How does it Affect the main output signal?
What does the soloing do to the main output signal?
Dr ZEE said:* walters, why are you asking these questions? What is your mixer/console (make/model), what exactly are you trying to do/achieve?
or is it just an abstract late Sunday-Night blah-blah?
/later
), where at leas it was stated, that the confusion may come from the fact, that "... different manufacturers have different names for, and different ways of arranging these functions.".... What do Solo, PFL and AFL do? Q/A at SOS
